Ford 2110 LCG serial #'s question............
Harry
05-29-1999 08:47:06
I've found these #'s on a 2110 LCG ford (so the sheet metal characters state). Here they are in the same position as stamped: 21122A C112442 5J8 Can someone knowledgeable please tell me what Model of tractor is indicated here? I know the sheet metal painted script indicates A "low center of gravity", but the front tires are not small; they look to be normal size (15 or 16 inch) to me.....What gives?? thanks for the help!!
Bern
06-01-1999 17:13:33
 Re: Ford 2110 LCG serial #'s question............ in reply to Harry, 05-29-1999 08:47:06
21122A is the model number. It means a 2000 series tractor, L.C.G., gas engine, single stage PTO, and 4 speed transmission. 5J8 is the date code. It means this tractor was manufactured on September 8, 1965.
C112442 is the tractor serial number. From this number I can tell you that your tractor was built in the States (C prefix).
RickB.
05-30-1999 04:51:41
The front tires & wheels could have been changed from the originals to a more common/less expensive size somewhere along the line. The front axle extension or knee will be much shorter (vertical dimension) on a LCG than a plain 2000 or 3000, if there is one of these in your area, you could compare them. 21122A is the model designation, I don't have a listing, but a dealer could determine what model this refers to. C112442 indicates a 1965 tractor, according to my info. 2,3,4 & 5000's were numbered together in this timeframe. Hope this helps.
