After 6 months of working on my 861 I finally got it running, problem is... it isn't running very smooth, but only when I push the plug wires all the way on until the connection click is felt. I converted it to 12 volt. It's got new wiring harness, distributor cap, rotor, rotor clip, spark plugs, spark plug wires, points, condenser, and a new 12 volt coil with internal resistor. Initial timing: 4 degrees B.T.D.C. at 450 rpm Idle speed: 450 rpm Distributor points: .024 to .026 Spark plug gap: .025 to .028 The wires are Motorcraft SIPCON, part number CPN 12259 B, from NH/CNH. Pushing the plug wire all the way onto the spark plug so that the connection click is felt seems to cause little or no spark delivered to the plug as if the plug can't pick up the spark - result, engine runs poorly, misfires. If I pull the plug wire off so that the metal in the plug wire is close to the spark plug end, (the boot is long enough to do this, see pic) the engine runs very smooth with no misfiring, this is the technique I used to set the timing and carburetor adjustments, but I can't leave the wires like that as they will come off when the tractor is moving. I've tested the plug wires resistance and they test good. I even bought another identical set of wires, they test the same, no improvement between sets when installed. The number 1 cylinder is the most problematic, however, the 2, 3, and 4 cylinder all seem to fire better when I pull the plug wire and let it just touch the tip of the spark plug. At times they will all fire when fully seated and I can drive the tractor all day, but something happens, I don't know what and it starts misfiring again. Engine Compression Test Results: #1 cylinder: 155 psi #2 cylinder: 140 psi #3 cylinder: 145 psi #4 cylinder: 155 psi Results after oil was added to cylinders: #1 cylinder: 165 psi #2 cylinder: 150 psi #3 cylinder: 150 psi #4 cylinder: 165 psi Any thoughts/suggestions?
Thanks, Matt
