Order Ford 801 Parts Online
1962 Ford 1801
David Stuehrman
05-13-1999 07:22:34
I have a 1962 Ford 1801 with a Select-O-SPEED transmission. The problem is I can't find any
parts for the transmission. Is it possible to put a different transmission in it's place?
Can anybody help
Thank You David
Bern
05-13-1999 17:42:02
 Re: 1962 Ford 1801 in reply to David Stuehrmann, 05-13-1999 07:22:34
Yes, you could put in a manual trans but it would be spendy because you would also need flywheel, clutch, rear axle parts, etc. in addition to the trans. Is your SOS a total loss? If not, repair it. If you can't find parts I'd dare say you're not looking real hard. Seal and gasket kits, clutch plates, and some other small parts are still available new. Used parts are plentiful in wrecking yards (at least I've never had trouble finding what I wanted).
