Order Ford NAA Parts Online
NAA 3pt Hydraulic troubleshooting
Don
05-09-1999 06:17:01
This may be a repeat question, but I'm new to fords. I got a '54 NAA and the 3pt. don't work, Could it be the pump or something internal? It has the external pump and I hooked up a hose from the plug hole to the reservior and it pumped oil there so it has volume of pumping but how do you check it has pressure from the pump? How cane I tell if this is a Jubilee? Sorry for so long a questions, But thanks for any help.
Craig
05-09-1999 07:36:28
 Re: NAA 3pt Hydraulic troubleshooting in reply to Don, 05-09-1999 06:17:01
Take out the test plug on the lift cover and put in 2000 psi guage. Tie the lift arms down to the rear axle and raise hydraulic lever and check psi on guage.
Don
05-09-1999 20:19:34
 Re: Re: NAA 3pt Hydraulic troubleshooting in reply to Craig, 05-09-1999 07:36:28
Where's the test plug? Is it infront of seat on the right, where remote hydraulics would go, I think? I tore top off rear end today, everything seems ok, Just wondering if the pump not putting out pressure now.
Dave
07-30-1999 12:21:22
 Re: Re: Re: NAA 3pt Hydraulic troubleshooting in reply to Don, 05-09-1999 20:19:34
having a problem with my case 1030 the tree point will not hardly lift any more we had to replace a seal on the hydralic pump now i think there is air in the line is there any way to bleed this off ? any suggestion would be great thanks in advance
Don
05-09-1999 20:18:02
