Order Ford 800 Parts Online
Ford 800 Tractor Hydraulics
Matt Smith
05-03-1999 08:42:13
Problems with hydraulic system. System will rapidly bounce or jerk implement in raised position. So far I have replaced lift piston O-ring and backup seal, along with all the O-rings on the lift cover and lift cylinder, plus installed a hydraulic pump repair kit. Any other suggestions?
srk
12-20-2000 02:25:01
 Re: Ford 800 Tractor Hydraulics in reply to Matt Smith, 05-03-1999 08:42:13
Sir I heard that Ford Tractors Hydraulis is one of the best Hydraulic Systems in Indian Market. I want to know the special features in this system.
Bern
05-03-1999 16:43:39
Question. Will implement settle all the way to the ground when you shut the engine off? If so, you have an internal leak. Possibly a worn control valve, leaking unload valve plug, lift piston seals, etc. A sticking unload valve will make the system dead, not bounce around like yours is. Try draining some of the oil out of the reservoir, remove access cover (one with dipstick), and look inside with a mirror and flashlight while your 3 point is settling down (engine off). By doing this you might be able to see exactly where your leak is. Could also be a lift cylinder safety valve, but these rarely give trouble.
Matt
05-04-1999 05:30:20
 Re: Re: Ford 800 Tractor Hydraulics in reply to Bern, 05-03-1999 16:43:39
Thanks. If I remember correctly, the implement settled to the ground when I shut the engine off, but I will check it again. I did replace the lift piston O-ring and backup seal, however I did not measure the piston O.D. or lift cylinder I.D. to check for clearance. The piston fit was fairly snug when I installed into lift cylinder so I don't think fluid is leaking past piston. However, I plan to check for internal leakage as you suggested and then go from there. Thanks again.
RickB.
05-03-1999 15:12:15
Possibilities include a faulty safety relief valve directly on the cylinder or a sticking unload valve.
