Order Ford 3000 Parts Online
3000 starter switch
Roger
04-22-1999 13:23:21
After several years of not having working gauges, I recently hooked everything up and got them to work. However when the switch is turned clockwise so that it stays in the "on" position the generator warning light stays on. Is this the way it should be?
Bern
04-22-1999 16:48:54
 Re: 3000 starter switch in reply to Roger , 04-22-1999 13:23:21
With the key switch in the "on" posistion and engine not running, both warning lights should be on (charge and oil). With the engine running, both should go out. If the charge light stays on, try polarizing your generator. If that doesn't cure it, remove generator, melt it down for a boat anchor, and install an internally regulated Delco alternator (kits to do this available from TISCO). Believe me when I say that you will save yourself much time and frustration. One last note - the above information assumes you have everything wired up correctly.
