Order Ford 4000 Parts Online
'63 4000 starter solenoid
GOFGA
09-30-2004 15:10:37
I have just replaced the starter solenoid and the thing won’t turn over when I press the starter. It will, however, turn over when I swap the switch. Only I don't want the tractor to start simply by turning the switch on.
Jim Cox
10-01-2004 10:32:26
 Re: '63 4000 starter solenoid in reply to GOFGA, 09-30-2004 15:10:37
here's some solenoid schematics, along with some Generator Tech info
Jim Cox SW Missouri
GOFGA
10-01-2004 15:33:25
 Re: '63 4000 starter solenoid in reply to Jim Cox, 10-01-2004 10:32:26
Thanks.He did a good job on the 8N!
Old Ford Mechanic
09-30-2004 17:53:20
Did you replace it with one made for the tractor?The ones for an automobile won't work.
GOFGA
10-01-2004 07:24:34
 Re: '63 4000 starter solenoid in reply to Old Ford Mechanic, 09-30-2004 17:53:20
I don't know .I got it from NAPA and they knew I was working on a tractor. I'll follow up with them. Thanks.
