Order Ford 8N Parts Online
Key left on, now won't start (48-8N)
Brian R.
03-20-1999 18:35:34
key was left" ON" my 8N. now it won't fire. has a front distributor. I took it out and the points look good and the coil tested good also. could it maybe be the condensor? Also, this drained the battery and had to be re-charged. Plenty of juice in that right now.
kg
03-22-1999 14:08:46
 Re: key left on, now won't start (48-8N) in reply to Brian R., 03-20-1999 18:35:34
make sure battery/cable connections are very clean and very tight. 6v systems aren't too tolerant. This was a common problem on my 2n.
FRANK L HILTON III
03-21-1999 17:14:32
POINTS COULD HAVE AFILM ON THEM KEY SWITCH COULD BE BAD CONDENSER COULD BE BAD AND ALSO CHECK THE RESITOR TOO
