Order Ford 861 Parts Online
Re: 861 power adjust wheels
Dan Robertson
01-23-2002 06:35:45
Yes Chris, the extensions are needed to keep the tire away from the fender when adjusted all the way in. The extensions were part of the power adjust rim option package. The owners manual details the adjusting procedure. No need to jack the wheel clear of the ground to adjust. You adjust the width by driving forward to adjust one side and backward to adjust the other. Works best to loosen one wheel center, make the adjustment, then proceed to the other side to repeat the process. Dan Robertson
Chris-Ms
01-23-2002 18:18:42
 Re: Re: 861 power adjust wheels in reply to Dan Robertson, 01-23-2002 06:35:45
Thanks Dan for the info.
Mike
01-23-2002 09:56:24
Dan,
Those must be different than the ones on our 6000, on ours you loosen the big nuts around the wheel center hub then go forward or back depending on if you want in or out, then retighten the big nuts making sure you center the rim.
Mike
