Sounds like you have a 3cy 2000. First thing i would do is get a set of manuals. The reprint owners manual is not much help.. but is so cheap you might as well get it as it has general tractor 'use' info... and explains thing like draft control.. and remote hyds.. etc.. A aftermarket shop manual like an I&T fo-31 is ok.. and realitively cheap... cheap enough to have even if you get the more expensive and more extensive ford shop manual. Go ahead and do a full tune up and fluid / filter change just ti find out where you are at. Depending on temp range.. a sae 30w or 15-w40 oil is fine for that machine unless you are in arctic or desert climates. I don't own a 2000.. but in general: serivce the air cleaner.. if it is oil bath, remove it and rinse it in solvent of choice.. many of us like diesel or kerosene.. etc... then dribble some oil down in it, and then refill the cup with engine grade oil. change crankcase oil and filter. Not sure if these still use the motorcraft fl-1a spin on or not.. but you should be able to check the filter that is on it. if it is a cannister.. check it to see if it is a napa 1004 cartridge.. etc. Service the trans/hyd/rear end oil. Generic utf can be used if it meets the CNh m2c134d spec. 9 most do ).. i get mine at walmart or TSC.. whichever is cheaper.. Points and new wires and condensor and distrib cap.. heck.. get a coil for it unless it also looks new. Clean up the engine wher ethe leak is so you can monitor it. Oh yeah.. post some pics .. we love pics.. and congrats on the new ownership. soundguy
