NAPA Coil
Michaels Dad
12-25-2007 09:37:58
Since Car Quest is the big player in this area, can anyone cross the NAPA coil number over to the equivalent at a Car Quest, and if so, how do you do it.
My plan is to replace the existing 6V coil and resister that are on my 640. Just planned on replacing the coil, and splicing the two wires together that went to the resister, anything else look out for?
Thanks and Merry Christmas
john in la
12-26-2007 01:33:29
 Re: NAPA Coil in reply to Michaels Dad, 12-25-2007 09:37:58
third party image
Do not know what brand Car Quest carries but even a dumb parts guy can cross Standard ignition part #'s. UC-15X
Air Force One
12-26-2007 05:58:25
 Re: NAPA Coil in reply to john in la, 12-26-2007 01:33:29
John! Can your cross ref the NAPA coil to a Advance Auto Parts type? Thanks!
john in la
12-26-2007 09:02:48
 Re: NAPA Coil in reply to Air Force One, 12-26-2007 05:58:25
Paul;
Advance auto sells Standard Ignition parts per their web site. But be fore warned they are not cheep.
Standard Ignition is like the largest manufacture of Ignition parts in the U.S.
While I know they have some dumb kids looking up parts at these places; and with out a year; model; and orginal color; they are at a lose; any "auto parts guy" should be able to cross the standard # to their store brand.
Michaels Dad
12-25-2007 13:53:08
 Re: NAPA Coil in reply to hzl6cm, 12-25-2007 09:37:58
MarkB_MI said: (quoted from post at 20:58:57 12/25/07) Just tell them you need a coil for a 12 volt system that doesn't require an external resistor. But unless you think there's something wrong with your current setup, there's no reason to switch coils.
Thanks, nothing wrong with the set up, just thinking about an upgrade.
If it ain't broke don't fix it..... ..got enough broke stuff now.
Jerry/MT
12-25-2007 12:59:20
The NAPA coil is IC-14SB . Don"t know what the equivalent Car Quest part number is.
GlenIdaho
12-25-2007 10:06:36
Merry Christmas;
Can't help you with the number, but I would think Car Quest could do that for you. Have you search the archives, it may have been mentioned before.
MarkB_MI
12-25-2007 11:58:57
 Re: NAPA Coil in reply to GlenIdaho, 12-25-2007 10:06:36
