Order Ford 801 Parts Online
801 cam follower pin
EDDIE SUTTON
09-26-2004 17:43:03
my book shows the pin installed. which way does the pin come out.HELP! thanks.
awhtx
09-27-2004 03:08:26
 Re: 801 cam follower pin in reply to EDDIE SUTTON, 09-26-2004 17:43:03
If you are talking about the pin in the hydraulic system, you drive it out in the direction that is the least amount of hammering. I replaced mine a couple of years ago and as I recall the pin is about 1.5" long (+ or - a little). One end of the pin is driven into a hole in the lift mechanism and the remainder of the pin just sticks out. Mine was stuck real good and required quite a bit of hammering to get it out. I was concerned that I was on the verge of breaking something.
EDDIE SUTTON
09-27-2004 06:50:24
 Re: 801 cam follower pin in reply to awhtx, 09-27-2004 03:08:26
thanks a lot awhtx, Thats the way I thought but wasnt sure.But I do know cast will break.Thanks again. ES
