Order Ford 8N Parts Online
8N- suddenly no noise or power when I hit the saft
123qse
11-27-2006 08:07:06
I"m dead! We have a break in the weather and I can"t get my cut firewood up. I relaced the selenoid, still nothing-thought I heard a click. If there is a blank spot on the starter armature, it would still make a noise? No problems all summer!No indication, first it was running then nothing electrical. Ballest?? Bob
john_bud
11-27-2006 19:12:45
 Re: 8N- suddenly no noise or power when I hit the in reply to 123qse, 11-27-2006 08:07:06
Ohm out the connections. Should have zero ohms. Also check the voltage AT THE STARTER when cranking. There shouldn't be much of a drop.
Then check each relay and switch. If all that is good, the starter or bendix may be bad. But, I'm thinking electrical connection.
jb
mwallen
11-27-2006 17:21:21
Had same problem one day fine,next nothing.Replaced pos.battery cable and has been fine ever since.
souNdguy
11-27-2006 12:11:26
Tap it with a hammer..(starter ).
Check to see if the bendix is stuck in the ring gear.
Soundguy
Jerry Cent. Mi.
11-27-2006 13:22:14
 Re: 8N- suddenly no noise or power when I hit the in reply to souNdguy, 11-27-2006 12:11:26
Try a hammer on the starter. It could have a brush hungup. Mine did the same thing.
old
11-27-2006 09:04:53
Check all battery cable coonections make sure they are clean brite and tight. Also you might try a differant battery
