Order Ford 4000 Parts Online
4000 Low on Power After Repair
Brad L in WNY
06-21-2001 07:10:13
Hello All-
I've got a '64 4000 Industrial and just got through:
1) Replacing the timing gears,
2) Resetting the valve clearances,
3) Setting the Points clearance,
4) Re-timing it,
5) Rebuilding the MS carburetor.
I'm fairly sure (?) that I've got it set to specifications, but when I hooked up the bush hog to mow down a field, it seemed like it was low on power as compared to before the repairs. I�ve fiddled with the power screw on the carb and it doesn�t seem to make much of a difference where I set it. The governor will kick in just fine under heavy load to power it through, but still it just seems like it lost some power. Any hints on what might be effecting it?
Thanks in advance,
Brad L, Medina NY
Brad L in WNY
06-25-2001 04:58:14
 Re: 4000 Low on Power After Repair in reply to Brad L in WNY, 06-21-2001 07:10:13
Thank you all for the help.
Just to let everyone know how this was finally resolved:
It seems that after putting the tractor back together after replacing the timing gears that the throttle linkage did not go back together as tight as before. When I manually 'floored' the throttle, it worked just as well as before the repair. So I guess the moral to this story is that sometimes it is the details that really matter.
And although the advance is a little bit off (timing at both idle and full RPM don�t both match spec at the same timing), the �64 has only a mechanical advance.
Lastly, good news (or not?) is that points gap and timing had very little effect on the overall performance and the full load performance is very insensitive to them.
MarkB
06-21-2001 15:57:22
Believe it or not, these engines will seem to be running just fine on two cylinders. That is, until you put a load on them!
Pull the plug wires loose one at a time while the engine's running (with insulated pliers). Chances are, you'll find that one or two cylinders are dead.
It's quite possible that you got two of the four plug wires swapped. Check the firing order vs. the rotation of the distributor.
Clarence
06-21-2001 07:27:51
check your vacuum & vacuum advance! , check points gap again & timing again also. Make sure that the spark is nice & blue.
