What I have: Converted a Ford 801 gas from 6v to 12v using a complete package kit from Tisco. I continue to use the 6 v starter, having rebuilt it.The problem: Starter solenoid will not work as intended. Details: I rewired the tractor following the directions sent with the 12v conversion kit, to a T. All systems seem to work as intended except the solenoid. I had a new solenoid on the shelf that I originally installed but it did not work so I ordered a new one from Tisco, Part number D2AF11450AA. The label on the new solenoid says “OEM applications: 742716 Ford Tractors 2000 -3000 1965/up with 4 ½ diameter starter.” This is the only one I could find in the Tisco catalog that seemed to match what I needed. I installed the new solenoid, connected all the wires in the wiring harness sent with the 12v kit following their diagram as follows: Red wire to Alternator and to plus side of Ampmeter. White wire to plus side of coil and to right side of Resistor. Red/white wire to battery side of solenoid and to minus side of ampmeter. Orange wire to –I- post on solenoid and to left side of terminal block. Yellow wire to –S- post on solenoid and to starter switch. Jumper wire from left side of Resistor to left side of terminal block. Left side wire of key switch to left side of terminal block. Jumper wire from right side of terminal block to minus side of ampmeter. Right side of key switch to right side of terminal block. When I turn the key on, I have power to the –I- post on the solenoid, when I turn the key off I do not have power to the –I- post. With the key on when I press the starter button nothing happens. I though I had a bad starter button so I took the –S- wire off and went direct to ground with the key on. Nothing happened. Transmission is in neutral, and the starter switch fully depresses. With the key on, when I jump from the –I- post to the –S- post, the starter works fine. With the key off, nothing happens with I jump from –I- to –S- post. I checked the starter switch wire (the yellow) for continuity and it was fine. With the key on, I have power to the –I- post, I jumped from ground to the –S- post and nothing happened. My understanding of solenoids, power to the –I- post warms up the solenoid, and when pressing the starter switch it goes to ground and completes the circuit. This isn’t happening. Questions: Have I done something wrong in the wiring? Do I have another bad solenoid? I am going this alone on a Saturday so I am stuck. Any and all suggestions are appreciated. Sorry for the long post.
