Order Ford 2000 Parts Online
'71 Ford 2000: dry sleeves
Guenther Sigott
05-29-2001 02:32:17
Hello everybody:
I'm having the engine of my Ford 2000 rebuilt at a machine shop. I'm glad the guys there suggested dry-sleeving the engine right away (we know about cavitation pinhole problems when boring oversize etc.)
Now, this is what interests me: The sleeves which they are putting in come without a ridge or land that would hold them in place. The machine shop has left a ridge at the cylinder bottoms standing rather than boring right through. So the sleeves will be held in place (apart from the press fit)by this ridge at the bottom and the head at the top. This is okay by me although it means boring the sleeves out at a subsequent rebuild (which I probably won't need given the small amount of hours I put on per year). Just out of interest, though, I'd like to know what is usually done with this kind of sleeve to keep them from slipping. Do people just rely on the press fit?
I'd appreciate any input on this subject.
Many thanks
Guenther Sigott
Norman Armadov
09-13-2005 16:01:13
 Re: '71 Ford 2000: dry sleeves in reply to Guenther Sigott, 05-29-2001 02:32:17
Hello Guenther, I am getting ready to have my Ford 2000 engine rebuild. Will you be kind enough to let me know how much it cost you to have your done and who did the work for you. Are you satisfied with the work? Hope to hear from you soon. Thanks Norman
marv
05-29-2001 21:11:03
I bore the block to the exact specs given in the Ford Service Bulletin. This makes for a very tight press fit. I use a 20 ton hydraulic press to install and put a band of red Locktite at the top and bottom. Haven't dropped a sleeve yet.
Guenther Sigott
05-30-2001 08:11:40
 Re: Re: '71 Ford 2000: dry sleeves in reply to marv, 05-29-2001 21:11:03
Thanks Marv for the info. Haven't got any experience with dry sleeves. So far I've only dealt with wet ones.
Cheers
Guenther Sigott
