Re: 631 Ford Lift problems
Mark H, Ont
05-26-2001 18:09:28
Have you checked/changed the oil lately? If it's creamy like a milkshake, you have water in the system, hence the warmup required.
Gary W Conger
05-26-2001 19:14:58
 Re: Re: 631 Ford Lift problems in reply to Mark H, Ont, 05-26-2001 18:09:28
The fluid in the lift is less than a year old and it has been under a shelter so no water should be in it at all.The fluid does not look milky. I had completly changed all the oils in it about a year ago.If you have any other suggestions please let me know and thanks for responding.
Chris White
06-02-2001 22:16:14
 Re: Re: Re: 631 Ford Lift problems in reply to Gary W Conger, 05-26-2001 19:14:58
If you mean the 3-point hitch there are 2 o-rings located under the transmission top cover. You have to take the seat off-then the cover and on the right side just inside the gasket flange are 2 small 0-rings, one is probably bad. I repaired one years ago,I hope this helps you.
