Sick 172
george
05-10-2001 23:25:26
I have a 1967 Garrett 15-b log skidder powered by a ford industrial 172 ci gas engine. I believe this engine is internally identical to the ones used in early ford tractors. It was rebuilt a few years ago it recently showed copper shavings in the engine oil and filter. Oil pressure dropped from 40# at idle to 10#. engine never missed a lick. I pulled engine and rod and main bearings are fine. Distributor and oil pump seem tight. I hate to keep tearing things apart for no reason. Anyone have any Idea where my copper deposits are coming from?
outdoorsknight
02-28-2005 15:22:58
 Re: sick 172 in reply to george, 05-10-2001 23:25:26
Replacement of engine: Have #200 Timberjack skidder built in early 60's with Ford 172ci gas industrial engine. Engine shot. Located Ford 201ci diesel out of late 60's Ford 4000 farm tractor. I'm I craze for thinking about pulling 172 gas engine and replacing it with 201 diesel engine, with little more Hp & better fuel economy.
How would engines match up at bell housing?
Some Ford 4000 tractors early had 172 and later had 201 engine.
snitkawl
05-12-2001 19:19:46
The 172 ci Ford engine has no cam bearings.
raytasch
05-12-2001 16:46:12
The only things I can think of that would throw copper through the system are wrist pin bushings or bearing inserts. ??? ray
Joseph Turrisi
05-12-2001 19:08:48
 Re: Re: sick 172 in reply to raytasch, 05-12-2001 16:46:12
worn cam bearing could cause both copper and lost of oil pressure
greg
05-12-2001 19:15:23
 Re: Re: Re: sick 172 in reply to Joseph Turrisi , 05-12-2001 19:08:48
Cam brgs and wrist pin bushings could be cause, but don't forget to closely inspect the thrust faces on your main brgs. If machine has a manual clutch, the forces exerted when releasing the clutch force the crankshaft forward, over time wearing out thethrust face on the thrust bearing. If unit is a torque converter/powershift type, these forces are greatly reduced, but still present to some degree. Check thrust surfaces before pulling pistons or cam. Past experience.
Joseph Turrisi
05-12-2001 19:08:45
Joseph Turrisi
05-12-2001 19:08:34
