Order Ford 9N Parts Online
Problem with 9N 3 point
Cory S.
05-06-2001 19:49:42
I have a 1948 9N, the problem I am having is that the 3 point will not pick up the attachments. PTO is engaged and the fluid level is good. Any suggestions? Thank you.
DonP
05-07-2001 13:38:03
 Re: Problem with 9N 3 point in reply to Cory S., 05-06-2001 19:49:42
If it lifts and lowers with nothing attached, the problem is generally air, the pump may need bleeding.
-Now if I just knew how to tell you how to do that...
-You may want to check the N board
