9700 series pto problem
c.k.
10-09-2004 15:56:47
pto suddenly quit. while checking control cable @ transmission, found bolt with long stem that locates valve had backed out. I went thru threaded hole with small screwdriver & lined up hole, installed bolt, but still won't engage. I guess valve & linkage got unhooked. question: can I remove pump on other side & get to it, or plan on splitting this cab tractor? thanks
Old Ford Mechanic
10-09-2004 20:50:24
 Re: 9700 series pto problem in reply to c.k., 10-09-2004 15:56:47
C.K.,After pondering on this awhile i seem to remember ecountering this problem several years ago.But i still believe that i ended up splitting the tractor to repair the problem.Your linkage connects to a fork type lever that controls the valve spool for the PTO brake.When the pin worked its way out the spool fell out of this fork and let it activate the brake band and stopping the PTO.It also can cause the line to break and the PTO componets to become misaligned.As Bern said I would go ahead and split the tractor and do it right.Even if it has a cab you can still do it without pulling it completely off.You need to look everthing over good while your in there.Now is the time to inspect the clutchpack and rebuild if its worn very much.Good luck with your repair.
Bern
10-09-2004 18:21:41
You could line up the parts by removing the 3-point lift cover, but since there's a chance you have other damage anyway, I'd split the thing and do it right.
Old Ford Mechanic
10-09-2004 17:15:17
C.K.,You will need to split the tractor to repair the problem.It probaly broke the oil supply tube.You don't have enough clearance through the pump access.
