Order Ford 841 Parts Online
Re: 841
Jim.UT
04-30-2001 20:51:08
Could make that tractor real handy for mowing. When you say Hi-Lo are you saying it has an overdrive range and an underdrive to go with the direct range? If so, you could more effectively avoid the weak 2nd gear of the 4 speed by using either 1st/overdrive or 3rd/underdrive.
Horseman
05-01-2001 08:13:49
 Re: Re: 841 in reply to Jim.UT, 04-30-2001 20:51:08
The 841 with the sherman will work great.Don't be afraid of it. There are lot's of them equiped with it out there. Jim, I thought it was the second gear in the five speed that was weak not the four? I was told the four speed is better for loader work and the five with live pto for ground work. but I've been wrong before.
