be sure to use 15w-40 diesel oil.. it will have a rating of ci-4 or the newer cj-4.. this oil is especially designed to handle the soot that gets in diesel oil, has special additives to fight the acid that comes from moisture that mixes with the sulfer from the diesel that creates sufuric acid.. and the oil is designed for extended changes... and will protect several years between changes.. you can change your oil somewhere between 100 hours to 500 hours of operation or every couple of years.. you can buy the oil in gallon containers at wally world for about $6.50 or less per gallon.. if you have the older style "cartrage" filter, go to ebay and get the spin-on adaptor to convert it to a newer type spin on filter.. then it will use the standard FL-1 motocraft or ph8a phram filter which can be had for about $2.50 or less.. so you see that oil changes will not be a problem and the new diesel oils will last much longer with better protection... use chevron delo 15w-40, or shell rotella 15w-40 or mobil delvac 1300 15w-40.. all are about $6.50 a gallon and most 5000's take about a gallon,, the rowcrops can take more.. this oil can be had all truck stops as well.. currently over the road trucks are getting up to a million miles between overhauls using this oil in canada and the US.. so as you can see,, this is not your granddads oil... keep a good battery in it with good battery cables.. on all fords after 1-1-1965, check the postive cable for chaffing where it runs down by the gas tank.. if the battery cable is worn, CHANGE IT OUT.. many of late model tractors are burnt up becuase the battery cable shorted out due to the swing battery tray.. so keep an eye on the positive cable and when it starts to crack a little, replace it.. about once every ten years will usually do fine.. but a good battery will crank it fast,, and that is very very important for starting.. as the cranking faster will generate the compression heat needed to fire off a diesel engine.. the compression head must reach about 400 degrees to fire off and a slow cranker will NOT do it... otherwise take care and the tractor will most certain out live you... hth.. bill
