Order Ford NAA Parts Online
ford jubilee
child
07-23-2004 18:57:38
Look at a ford 2000 one of the first made look the same as the jubilee but blue. The man says that it is the same tractor is it?
RPM
07-24-2004 09:08:32
 Re: ford jubilee in reply to child, 07-23-2004 18:57:38
The 2000, has Improvments over the Jubilee.
Improved Hydraulics & Rear axle does not have a hub & big nut to come loose . Jubillee came only with the four speed trans.And a 134 gas engine. The 2000 came with the same 134 gas engine. you could get a diesel in the 2000 2000 came in four speed , five speed, & live PTO and the SOS trans. Power Steering on the 2000 But not the Jub.
The 2000 four cylinder was a better tractor than the jubilee If you was to work it IMO. I like the diesel
Joe(TX)
07-24-2004 07:00:49
The 2000 is esentially the same as rhe 601 series. The engines are the same as the NAA but has differances in the lift, among other minorthings.
RICKWI
07-23-2004 19:11:52
No. Same number of wheels and tires, but that's about it.
