Order Ford 6000 Parts Online
Ford 6000 Hydraulic lift
Jimmy Willfiord
01-25-2004 14:34:28
I have a Ford 6000 tractor that needs dry nitrogen to make the lift perform properly. In the manual, it says there is kit that you can get to install the nitrogen. I have contacted the Ford dealer about the kit and it is a no longer stocked item. I was wondering if someone knows what to use and where you can obtain this nitrogen.
Thanks
Jimmy
Philip
01-26-2004 04:04:25
 Re: Ford 6000 Hydraulic lift in reply to Jimmy Willfiord, 01-25-2004 14:34:28
Jimmy, I have some more information on the nitrogen system. Contact me directly. Philip.
Harrison
01-25-2004 16:02:32
Be careful. I have a 61 ford 6000 and from experience I can tell you that system is very dangerous.That said you can find the nitrogen at most any welding shop and the "charging kit" can easily be made with a gauge and a few fittings. I do like these old 6000 tractors and when serviced and used properly I think they are hard to beat.
Geo in SD
01-25-2004 15:53:41
You might check with a [shudder] John Deere dealer and see if he will recharge your accumulator. The later Deeres use a variety of accumulators in their tractors. The dealer I recently worked for had all the equip for recharging. All dealers should have this. Whether they will do your job is another thing. It might be better to remove the accumulator and take it to them. Careful, they are charged at about 1800 psi if I remember right, and can hurt you. Another thing, a lot of industrial equipment uses acc's also, and if you are in an area of some heavier industry, it might be possible to get some help there. Hope this helps
goofus fr L.A.
01-26-2004 08:37:18
 Re: Re: Ford 6000 Hydraulic lift in reply to Geo in SD, 01-25-2004 15:53:41
I bypassed the accumalator on a tractor, and it worked for years, with the acc shut down.May not work for you. goof
