Ford850
Harv
01-18-2004 15:11:09
I would like to replace the thermostat in my newly purchased ford 850. I have a manual(fo-20), but it does not say a thing about where the thermostat is. In the 8N i had it was in the hose, is the 850 the same?. I also still have a new thermostat for the 8N,will it fit the 850. Any advise would be most appreciated. Harv
Dave H (NY)
01-19-2004 06:52:25
 Re: Ford850 in reply to Harv, 01-18-2004 15:11:09
Thermostats for the 8N and 850 are totally different.
raytasch
01-18-2004 15:56:06
T-stat is in the thermostat housing. It is the small piece the top radiator hose fastens to. It is held on to the front of the head with two bolts. Use caution when bolting the housing back, make sure the T-stat is positioned right or you can crack the housing.
ray
