Order Ford 4000 Parts Online
Ford 4000 engine problem
Gerry Crook
03-29-2001 15:42:12
4000 series ford only numbers I can make out are 84201D located below the starter(and the 8 is questionable). Its a diesel and when I start it it runs fine for 30 - 60 seconds and then it begins to blow out the air intake and oil breather on the side of the valve cover. Sound from exhaust changes. The engine does not make any strange sounds that I can detect. Smell of diesel becomes very strong with a lot of smoke. Could it be a stuck intake valve? Anything that can be done w/o major work?
Dave
03-29-2001 16:54:50
 Re: Ford 4000 engine problem in reply to Gerry Crook, 03-29-2001 15:42:12
I would almost bet it is your injector pump
timing. Is it a simms or c.a.v. ?
Gerry Crook
03-29-2001 17:47:36
 Re: Re: Ford 4000 engine problem in reply to Dave, 03-29-2001 16:54:50
I don't know how to tell. The top of it has "ROOSA MASTER" stamped on it. The side plate has many many numbers but no name that I can see.
