Order Ford 800 Parts Online
800 Help
Robbie (Ga.)
03-28-2001 18:31:28
I have an 800 that runs out of gas(or something) after running about 2 minutes under load. It will run longer with the choke out but no power. I have checked the tank, its clean--blown air through the gas line--fuel flows freely. I have cleaned carburator 3 times,no visible problem. I have cleaned air filter and pipe,no problem. I have a new coil,points,condenser,plugs,wires and battery.It starts good but I think its fuel related. New gas is in tank. Help!!!!
mike in fla.
03-29-2001 18:35:00
 Re: 800 Help in reply to Robbie (Ga.), 03-28-2001 18:31:28
robbie,be sure to check the screw that holds the sediment bowlto the carb.it only takes a miniscule piece of trash to slow fuel flow,also check carb..float for proper height,also check for burr;s where needle valve seats,posiable the needle valve is sticking closed,just some things to check,hope it helps.
mike in fla.
03-29-2001 18:34:47
Jerry D in NC
03-29-2001 09:52:26
What happens if you take the gas line loose at the carb and open the fuel shutoff. Let it run for a couple of minutes to see if it stops up.
RICKWI
03-28-2001 20:10:42
Spose it could be a plugged vent in the cap, or the wrong cap? Try running it with the cap loose.
DonP
03-30-2001 08:58:42
 Re: Re: 800 Help in reply to RICKWI, 03-28-2001 20:10:42
That happened to my 641. It would run for hours at idle, but when I put it to work, it bogged down and spit black smoke so bad I thought it was on fire. It was a wonder I didn't suck the tank flat, the vacuum was pretty intense.
