Order Ford 601 Parts Online
Ford 601 Wiring color charts
Jeff Mans
12-14-2003 11:59:07
I could use an accurate wiring chart with color codes. The tractor is a 601 workmaster GAS. any help woud be appreciated.
Jim.UT
12-14-2003 17:20:54
 Re: Ford 601 Wiring color charts in reply to Jeff Mans, 12-14-2003 11:59:07
third party image
Here's the one I used when I re wired my 850
Jeff Mans
12-14-2003 17:52:45
 Re: Re: Ford 601 Wiring color charts in reply to Jim.UT, 12-14-2003 17:20:54
12 Volt?
Jim.UT
12-15-2003 11:23:58
 Re: Re: Re: Ford 601 Wiring color charts in reply to Jeff Mans, 12-14-2003 17:52:45
Nope, sorry that's a 6V diagram. I assumed you wanted 6V when you said it was a 601 gas engine. Only the diesels from that series got the 12 V from the factory. If your gas 601 is a 12 V then it's a conversion and all bets are off since there are so many different ways to accomplish a 12V conversion.
The factory 12V diesel wiring diagram is also on the Vintage Ford Tractor Resource.
Jeff Mans
12-15-2003 19:27:37
 Re: Re: Re: Re: Ford 601 Wiring color charts in reply to Jim.UT, 12-15-2003 11:23:58
thank you
