Order Ford 600 Parts Online
Ford 4600 pre-heater
Rhydian Edwards
11-05-2003 14:28:24
I've owned a 4600 1980 for about one year now in the hills of Wales and its great! The only problem is that to start it on a cold morning is not somthing to be rushed. How does the factory heater work on this machine (air/fuel warmer?)or is there a kit avalable to fit a heater to it? The machine is a standard UK spec with cab and the key only turns to the right.
Jerry/MT
11-06-2003 08:55:45
 Re: Ford 4600 pre-heater in reply to Rhydian Edwards, 11-05-2003 14:28:24
There are block heaters available that fit in the core plug holes. They heat the coolant with an electric element. I believe the Thermostart, which burns fuel in the intake manifold to supply start up heat, is only supposed to be good down to 5oF.
RickB.
11-05-2003 15:39:17
There is an un-detented position in the keyswitch that energises the thermostart. Just past "ON" , the dash lights will go out, but the starter is not yet engaged. This is where the T'start is energised. 15 to 40 seconds, depending on ambient temp.
