diesel pump problems
Cook
11-03-2003 09:43:44
Here's a problem to test the skills of any tractor man...
I just took off all the pumps,etc on my 3000 diesel (c.1970) for repainting. When I put it all back, it cranks and runs on starter fluid but dies. So I did two things--
(1) check timing (Simms inline--19 on flywheel after frontmost cylinder puts out air through injector hole, matched pump shaft markings behind starter motor and gear markings behind radiator hose). (2) I then bled it to the injector nuts, then kept running it on a whole can of starter fluid...No magic...
(Here are some other clues: the lift pump was clogged so I had to clean it out and put it back. This tractor has been unstartable without starter fluid for a couple of years. There are no starting aids and the only thing left working on console is throttle. There is no cable to diesel stop lever. For your information, I am 26 years old and beginning a new relationship with a tractor. I would really appreciate any old-timers helping me out.
Charles
11-03-2003 11:58:13
 Re: diesel pump problems in reply to Cook, 11-03-2003 09:43:44
Yor are being tough on it using that much starting fluid, take to the shop and get them to fix, do replace diesel stop before you get hurt.
old
11-03-2003 11:39:58
sounds like you may have a weak pump and taking it off was the straw that broke the back so to speak I'd take it to a diesel shop and have the pump checked out. By the way if that is whats wrong hold on it will cost around $500 hope this helps you some
