Order Ford 801 Parts Online
Ford 1801 with a Sherman four wheel drive front en
Mel Rumbaugh
10-06-2003 15:51:36
I have a Ford 1801 with a Sherman four wheel drive front end, Sherman loader and Sherman Backhoe. I am in need the clutch pack that goes just behind the front difarential on the front axel. The splines on the inside of my old housing are gone.
Tony Jacobs
10-12-2003 06:49:55
 Re: Ford 1801 with a Sherman four wheel drive fron in reply to Mel Rumbaugh, 10-06-2003 15:51:36
Hi Mel, I just thought I would post for you about your tractor front end problem, give me a call or email me if you need parts. Sherman/Napco did build front axles just like Elenco did but I do not believe they ever built an Industrial unit for the 1801 series tractors. Thanks Tony Jacobs
Mel Rumbaugh
10-12-2003 07:57:51
 Re: Re: Ford 1801 with a Sherman four wheel drive in reply to Tony Jacobs , 10-12-2003 06:49:55
Hi Tony,
Thank you for your response.
I am not very knowledgeable about Ford Tractors. I purchased what I was told was a Ford 801 with a Sherman Backhoe and front bucket several years ago for use on a "play" farm I own. Upon further investigation I am led to believe it is in actuality an 1801. I am not sure what the differences are, but my tractor had NO PTO nor does it have locking breaks.
It does have what appears to be a live front axle drive unit, but it does not work.I found that what appears to be a slip clutch (for want of a better description) on a shaft running between the transmission and the front axel pumpkin. This part is completely stripped out inside.
I can send you pictures of the part and one of the complete front-end axel if that would help.
Mel
forworkma
10-07-2003 06:15:19
You probably have an Elenco Front wheel assist. The guy who knows about these, and has parts, is Tony Jacobs. You can contact him-
tjacobie@aol.com
413-267-5087
Good luck!
