Order Ford NAA Parts Online
I still have the NAA Golden Jubilee Collector's Edition
Dennis
03-16-2001 08:18:04
That is if anyone is still interested
Walt
03-19-2001 11:15:06
 Re: i still have the NAA Golden Jubilee Collector's Edition in reply to Dennis, 03-16-2001 08:18:04
Make that four people with Jubes. Mine started leaking gear oil out of the steering gear box; you know, where the levers are attached that hook to the steering links. I assume its the seals at the base of each lever. Any of you ever replace these seals? If so, how involved is the job?
Kev8n
03-20-2001 18:40:46
 Re: Re: i still have the NAA Golden Jubilee Collector's Edition in reply to Walt, 03-19-2001 11:15:06
We (Dad and I) just replaced the gaskets on the steering links because they were leaking. According to the manual, there are two seals behind the bushings, plus the fiber seal that is on the outside. I got the impression from the book that you have to take the whole steering box out to replace the seals.
However, what we did..
Took off the steering links from the levers.
Took off the nut which held the levers.
Used a Gear/drum puller to pull the levers off the shafts. New project.. required new tool.
We picked up a two rubber seals and two fiber washers from the NH dealer. The rubber washer fit perfectly inside a grooved area between the steering box and the steering shaft.
The fiber washer fit over the shafts and between steering box and the levers.
Reinstalled the levers and the nut.. the shaft from the steering column has one or two flat spots that match up with the inside of the levers.
Again.. not sure if that was the "proper" solution, but we don't have any leaks so far.
Took about an hour or two...
I'd be interested what solution you ended up with.
Kevin
'53 Golden Jubilee
'49 8N
Me too!
03-16-2001 11:52:47
I still have my Ford too.
Walt
03-21-2001 18:09:11
 Re: Re: i still have the NAA Golden Jubilee Collector's Edition in reply to Me too!, 03-16-2001 11:52:47
My local NH dealer said to do exactly what you did so I assume this should work and that you don't need to take apart the steering gear box. Thanks for your input.
I have one also------ and then
03-16-2001 10:19:20
puzzled
