Order Ford 960 Parts Online
960 hitch adj problems
Eric
08-27-2003 21:00:47
I have the hitch off of my 960 ford. I installed new o-ring on the piston and new gaskets. I have the guages that the I&T manual show. The problem is that when I try to adj the constant draft I run out of threads on the turnbuckle that hooks to the control valve spool. I tried replacing the draft control fork with ones from two other tractors and this does not help. Any thing that I am missing or I can check on. Thanks for any help.
Scott
08-28-2003 04:16:14
 Re: 960 hitch adj problems in reply to Eric, 08-27-2003 21:00:47
You need to bend the rod going back to the large spring at the top link rocker toward the front of the tractor.
