Order Ford 3400 Parts Online
Ford 3400 / PTO
Paul
08-17-2003 20:10:21
I just purchased a ford 3400 without pto. What is involved to add it? Thanks,Paul
HERB/PA
08-19-2003 04:59:40
 Re: Ford 3400 / PTO in reply to Paul, 08-17-2003 20:10:21
Depending on what you want to do with the pto, you can use the hydraulic pump mounted on front of crankshaft to power hydraulic motors for various attachments. My 3400 has a hydraulic sickle bar mower on it that you can raise and lower from seat.
RickB.
08-18-2003 16:55:06
Probably more than you will want to do. Best way to add PTO is find a flywheel, double clutch assembly, complete transmission with PTO drive, and PTO shifter and output shaft. Might as well sell the 3400 and buy a tractor with PTO.
