Order Ford 841 Parts Online
Ford 841 Tractor
Wayne
03-12-2001 13:23:45
I have recently changed an 841 diesel over to gas. I would like to rewire the entire tractor, and I am wondering what things regarding the wiring harness will be different. Also, what guage of wire should be used?
Tony Jacobs
03-12-2001 20:01:37
 Re: Ford 841 Tractor in reply to Wayne, 03-12-2001 13:23:45
Hi Wayne , The correct original wiring harness is available from Ford / New Holland , the cost is about $40 , just make sure you order it for a 6 volt gas tractor . What was wrong with the Diesel engine ? What are you going to do with the parts from it ? Where are you located ? Thanks Tony Jacobs
Al English
03-12-2001 17:59:15
Hi Wayne, The diesel wiring harness would have provisions for the manifold heaters, which you no longer need. What you are missing is the ignition/distributor wiring. 16 gauge wire is adequate for the ignition, but if you have to buy wire I'd go with 14 gauge. Good luck...Al English
