Order Ford 2000 Parts Online
2000 diesel ideling wide open
Ree
07-13-2003 10:45:47
I have a 2000 Ford Diesel, 3 cylinder that has started idleing wide open. The trottle control moves, but will only make it faster. The only way to get it to turn at less rpm's is with the choke. It had been doing some surging, but just started running wide open. It will slow down if under enough of a load, as in bushhoging in heavy tall grass. Any ideas?
bill
07-13-2003 19:13:03
 Re: 2000 diesel ideling wide open in reply to Ree, 07-13-2003 10:45:47
its not a choke, its a fuel shutoff..
and if the linkage is working correctly, you have a defective injector pump.. the govenor ring is coming apart and causing the pump to run fast all the time...
pull the pump and take it in to an injector pump rebuilding place... expect about $650 for a rebuild...
sorry the news isnt any better...
good luck.. Bill
