Battery
John
06-30-2003 04:46:25
Obtained a NAA Jubilee little over a month ago, appears to be in origianl condition. But had to jump start it, noticed that positvie cable was on negitive post. Not sure if this is the way it was built or the person before me changed battery and did not spend money for longer cables.
koontz
06-30-2003 19:32:17
 Re: Battery in reply to John, 06-30-2003 04:46:25
try not to make a habit of jumping your ford,, get a manual for it at the local dealer or on this www site: i have kept mine as a 6 volt positive ground system to keep it orginal, but you wil cuss when starting it.. keep the electrial system in good shape so that it starts, this will help,, otherwise you may need to switch to a 12 volt system & change coil , some wiring, generator, sos so (lights) go to a pos/pos so you can jump it with your truck,mine's a work horse
David Donaldson
06-30-2003 10:52:54
The NAA originally had a positive ground. Check out>Link
Did you got it running? and did you change the battery terminals around? The posts on my 861 are different sizes so you cannot get them backwards.
