Hub City Over- running coupler
Charles
06-26-2003 06:06:27
I know this is way off the subject. Has any one had any dealing with a Hub City overrunning coupler? This paticular type coupler is designed with a quick release concept-spring loaded-rotates 30 degrees by hand for quick release. Part # 0331-00010. All input appreciated
Fessman
06-26-2003 18:37:14
 Re: Hub City Over- running coupler in reply to Charles, 06-26-2003 06:06:27
I have several hub city couplers including that one. But I have never used it. I plan on changing the shaft over to 1 3/8" and using it then. I have been using the std hub city with the roll pin. I have been having a lot of success with the hub city brand and would highly recommend it. Note the std hub city style is rated for 75 hp, and the one you are looking at is rated for 125hp. Therefore it should last a long time.
Fessman
