Order Ford 3000 Parts Online
Ford 3000 bled down
Michael
06-18-2003 06:25:35
My hydraulics bleed down very quickly. I pulled off the side plate and it is not leaking from the piston. I have already replaced the piston rings, the control valve and bushing, the safety valve, and the check valve ball. About the only thing that I did not replace is the check valve seat and oring around the check valve seat because I did not have the tool to pull it out. Could this be the problem, or does anyone else have an suggestion as to why this is leaking down? Thanks.
