Can't see timing marks, Help?
cbburrows
06-14-2003 07:58:45
I want to install an electronic ignition on my 660, but I tried a timing light on the flywheel first and was unable to read any of the timing marks. Any suggestions, or just leave the old points in?
Thanks,
Chuck
Tim
06-20-2003 10:36:30
 Re: Can't see timing marks, Help? in reply to cbburrows, 06-14-2003 07:58:45
Same problem .... with tractor not running!! use a screwdriver to turn the flywheel until you get around to the timming marks .... then dot the correct mark with red fingernail polish so you can see it when its running.
Bill Oakes
06-14-2003 08:13:50
Hi Chuck,
I have experienced the same difficulty; here's what I did. Turn the engine over by hand while watching for the timing marks in the little window; they are really there. Once you find them, clean that area of the flywheel well and then you should be able to see them with your timing light. On my 3 cylinder 4000, I actually had to pull the starter and turn the engine over with a big screwdriver. You will love the electronic ignition. You will need a good battery and a healthy electrical system because if the system voltage is pulled down below about 4.5 volts, the electronics won't fire.
