730 loader on a 3000
front mount
Bill Oakes
06-07-2003 11:23:33
I bought a 730 loader for my 4000SU (which I believe has a 3000 front axle. I have two questions:
1. There appears to be only 2 - 9/16, course thread holes in the front cast iron housing to hang the front of the loader from. Is this sufficient? Are all 3000 loaders mounted this way?
2. The hydraulic lines that run around the inside of the front loader frame seem like they will be awfully close to the sheet metal of the nose section. Is the nose section the same size on 3000 and 4000 Fords?
I am close to being in over my head on this project, so would really appreciate any advice you can offer. Thanks!
bill
06-07-2003 13:17:50
 Re: 730 loader on a 3000 - front mount in reply to Bill Oakes, 06-07-2003 11:23:33
no , yes yes yes..
drill the other two holes in the front bolter or casting.. thats how mine is put on.. and yes the sheet metal is the same, and yes it it close and yes, they are all mounted this way..but you will need an extender plate on each side at the rear axles... as only one hole will line up in front of the rear axle,, and the adaptor plate conects the rear bolt... if i remember correctly.. the 730 is actually the correct loader for that series and a very heavy duty loader,, but slightly lighter than the 727 loader...
good luck... Bill
