Order Ford 5000 Parts Online
Ford 5000- more questions:
JimKS
04-29-2003 19:07:25
Thanks for answering my previous questions, folks. As often happens, when I got an answer that my differential and transmission are filled separately, this has led to another question: How do I check the oil in my differential? I've looked on the housing and can't find a level plug on the rear section. BTW, the manual that I just got says that the hydraulics use oil from the differential housing, but doesn't mention where to check the oil. So I assume that this means that hydraulic oil goes in the differential housing, and not gear oil? Thanks, folks. This is for my inlaws' tractor, so I gotta get it right.
JAE-Tx
04-30-2003 06:46:57
 Re: ford 5000- more questions: in reply to JimKS, 04-29-2003 19:07:25
There is a square-ended pipe plug on the housing next to the PTO. Standing behind the 5000 you'll be facing it. It is a level plug - fill until it runs out the plug hole.
Funny - It's obvious once you see it, but I have to crawl all over my 5000 to remind myself where it is every time ...
