Order Ford 3000 Parts Online
Ford 3000 gas compression test
David (Alabama)
04-23-2003 10:24:28
Further diagnosing 3000 Ford. I have established that I have a carb problem as per recent posts. This morning I did a compression test with the following results. Cyl# 1 dry -98 psi, cyl #2 dry -105 psi, cyl# 3 dry -98 psi. Then cyl#1 wet -110 psi, cyl #2 wet -110 psi, cyl #3 wet - 102 psi. The engine runs good save the carb problem, I have to run with the choke about 3/4 closed. No smoke and adequate power. There is a slight poofing sound from time to time at idle. And upon removal of plugs, found that they were very sooty. I attribute this to the carb problem though. Engine rebuild indicated? Any comments and/or suggestions appreciated. Thanks to everyone, I have received lots of good advice.
David
Rick H. Ga.
04-23-2003 12:52:46
 Re: Ford 3000 gas compression test in reply to David (Alabama), 04-23-2003 10:24:28
Hi David,
I have read that the Ford 3 cylinder gas engine runs about 100 to 150 psi and the diesel engine runs about 300 to 500 psi. Not sure about the absolute minimum psi but if the engine does not smoke or burn oil and cranks easy I would get the carb problem fixed and run it until it shows obvious signs of needing an overhaul. HTH. Rick H. Ga.
albe
04-25-2003 10:24:12
 Re: Re: Ford 3000 gas compression test in reply to Rick H. Ga., 04-23-2003 12:52:46
It could also be an ignition problem. A rich mixture is easier to fire than a lean one. I'd also check out coil, wires, plugs, etc. albe
David (Ala)
04-23-2003 13:18:23
Thanks Rick, you just summed up my thoughts exactly. David
