Order Ford 8N Parts Online
8n transmission problem
Doug
04-21-2003 10:39:39
I bought a 1950 8n in that I had to put together it runs fine,no noises in transmission,but when I replaced the 90 wt. in trans. I took out 12 gallons of fluid, I replaced it with 5 gallons of 90 weight,now the gears sound like they are grinding in the rear end. any suggestions???
TimK
04-23-2003 08:01:26
 Re: 8n transmission problem in reply to Doug, 04-21-2003 10:39:39
Twelve gallons ! I can't understand why it didn't leak from the axles. Anyhow, I think the overfill was on purpose by someone to mask the sound of gears grinding. You emptied it and filled it the right way, and now you have the noise, which means a mechanical problem. That's my $.02
