Order Ford 3000 Parts Online
Ford 3000 gas carb replace. Holley or Zenith
David (Alabama)
04-19-2003 12:49:52
Finally decided to replace carb. Reading earlier posts, most seem to suggest going to Zenith replacement instead of using Holley again. Are there modifications required for this change? Any reccomendations appreciated.
Thanks, David
Catskill Pete
04-21-2003 09:00:17
 Re: Ford 3000 gas carb replace. Holley or Zenith in reply to David (Alabama), 04-19-2003 12:49:52
I have replaced a Holley with a Zenith, for a client, on a 3cyl. 4000. He thinks it was a major improvement. The only modification I had to do was alter the fuel line.
Ken
04-20-2003 09:17:35
I replaced the Holly with a Zenith on my 3 cyl 2000, and it really made a difference. No hesitation at all. The Holly worked good, but it would always hesitate, when increasing engine speed.
Eddie
04-20-2003 20:38:42
 Re: Re: Ford 3000 gas carb replace. Holley or Zenith in reply to Ken, 04-20-2003 09:17:35
Let me know how it work when you find out. I have a 2000 ford that doing the same thing. I have to run with choke on. Good luck, Eddie
