Oil drip from hole of transmission
tom
04-17-2003 17:38:50
While having the 871SOS on jack stands, I have a consistent drip of fluid from a small hole underneath the transmission.
I am thinking it is a weep hole that may require a cotter pin???
And because the front is now up a little higher the fluid is just weeping through that hole?
Or, am I off-base and that hole should not be there? tom
Larry NCKS
04-18-2003 05:18:42
 Re: oil drip from hole of transmission in reply to tom, 04-17-2003 17:38:50
You either have a front transmission seal leak or a rear mail seal leak. This hole is supposed to be there to prevent filling of the bell housing cavity with leaking oil.
Smitty
04-17-2003 18:12:50
Hole is supposed to be there and a cotter pin in it.
