Lucus Generator
Chuck
04-10-2003 13:37:48
I have a 1971 4500TLB. The generator isn't putting out. If I ground out the field terminal and take a reading at the armature terminal, shouldn't the volts shoot up? Are there any other ways to trouble-shoot before I take it in to get rebuilt?
Jerry D in NC
04-10-2003 19:38:53
 Re: Lucus Generator in reply to Chuck, 04-10-2003 13:37:48
Yes there is anotgher way. If you follow the procedure that I sent you for testing the generator on the tractor it will give an accurate indication of the generators condition. You disconnect the two wires from the generator and the jumper the generator terminals together. Place the positive lead from the voltmeter on one of the terminals and the other on ground. If the voltage rises relational to the tractor RPM's then the generator is fine and the regulator is the next suspect. Grounding the field should cause it to not generate electricity.
Chuck
04-11-2003 02:48:12
 Re: Re: Lucus Generator in reply to Jerry D in NC, 04-10-2003 19:38:53
Thanks again Jerry. Your right. I guess I'm confusing the ford 4500 with my positive ground 8n.
