Order Ford 2000 Parts Online
Ford 2000 1967 3cyl diesel Hydraulic filter??
Troy
04-07-2003 08:17:43
Ok I bet someone is really going to get a kick out of this. I actually have the ford shop manuals for this tractor. However I can't seem to find the location of the Hydraulic filter so I can replace it. The manual says it is located in the center of the rear axle. Which would be the siphon filter coming of of the pump. I am clueless!! I dont know what to remove to get to the filter can anyone help???
bill
04-07-2003 11:03:13
 Re: Ford 2000 1967 3cyl diesel Hydraulic filter?? in reply to Troy, 04-07-2003 08:17:43
actually it is on the return line, not the siphon line. the life will return any fluid not used through a tube back to the center of the rear housing.. the tube has a fiter on the end of it with a spring loaded bypass valve so that if it cloggs, the little spring assembly at the bottom will simply open... the pump has a suction tube on it with only a big screen assembly that can be cleaned as well
good luck bill
Troy
04-07-2003 13:51:08
 Re: Re: Ford 2000 1967 3cyl diesel Hydraulic filter?? in reply to bill, 04-07-2003 11:03:13
Bill I now understand that but where is this screen that can be cleaned?? I have the ford service manuals however I cant find anything like that and cant locate the filter to clean it could you help me?
