821 lube question
John in Austin
04-01-2003 11:39:02
third party image
I would like to change the transmission and differential (if that is what it is called on a tractor) lube on a 1958 821. It does not have a three point hitch but does have a PTO for the backhoe. Transmission is a 4 speed. Do I just use 90W or is there something else I should put in it? Thanks in advance, John in Austin
Bill-AZ
04-03-2003 07:55:39
 Re: 821 lube question in reply to John in Austin TX, 04-01-2003 11:39:02
John your tractor is an 1821 Industrial. Take a look at this site and see if it helps you.
Scott
04-01-2003 16:16:49
You have a 1821 model, you can use either 134 hydraulic/transmission oil or 80w90 gear oil since you do not have a 3 point hitch, put about 2 gallon in the hydraulic compartment since I do not believe yours has a dipstick to check the level and fill by removing the seat mount plate and seal it when reinstalling.
John in Austin TX
04-02-2003 11:06:05
 Re: Re: 821 lube question in reply to Scott, 04-01-2003 16:16:49
third party image
Scott, Is my tractor a Hundred and one series or thousand series. What is the diffrence in the 801series and the 1821? I figured it was a 821 even though it showed 1821 on the hood. John
Jim.UT
04-01-2003 14:59:06
Here's a link to a thread on the subject from the past. The "right" stuff for your diff is a matter of preference, but do the research first. Then do what you feel is best.
