Ford 3000 clutch
Author |
Bruce Maresh
03-26-2003 15:27:41
my dad has a ford 3000 and the clutch is stuck in the release position. when you step on the clutch pedal, the clutch rod just wants to bend and the bell crank wont move. this leads me to believe either the bell crank is seized or the throw out bearing is stuck on the input shaft collar. my question is there any way to access the clutch area for a visual inspection? if you remove the steering box, is there an opening to the clutch area i am an automotive master tech with 25 years experience but have not done much work on tractors. any help would be appreciated thanks bruce maresh
SCOTT
03-31-2003 22:56:54
Re: Ford 3000 clutch in reply to Bruce Maresh, 03-26-2003 15:27:41
I HAVE SOME "NEW-OLD"STOCK OF CLUTCH KITS ON HAND AND CAN SAVE YOU A LITTLE MONEY IF YOU WOULD LIKE TO GIVE ME A SHOUT.THESE KITS ARE WITH RELEASE & PILOT BEARINGS.NOT FOR SURE WHAT CLUTCH YOU HAVE BUT I HAVE KITS FOR ALL FORD MODELS ON HAND.LET ME KNOW IF I CAN HELP IN ANYWAY.THANKS
RickB.
03-27-2003 17:45:49
First, disconnect the clutch rod and make sure the cross shaft is not siezed in the clutch housing. If it is, I'd get it freed up without further disassembly. It should rotate somewhat freely until the release bearing contacts the clutch fingers. You can access the clutch from the top as suggested, but you can't fix much of anything from there. Splitting the tractor is the best access to the clutch, and you don't have to remove 1/2 of the items the other poster claims. I could split a 3000 in less time than it would take me to get the tank and steering box off it. And then if it needs clutch work, it needs to be split anyways.
Gary-Miss
03-27-2003 06:15:31
Yes-Unplug the wiring harness in front of the fuel tank, shut the fuel off,disconnect the fuel return, remove the bolts that fasten the fuel tank bracket to the back of the head, remove the tied rods, remove the four half inch bolts that hold the steering box to the clutch housing, go through the steering wheel to the housing with a suitable rope, chain, belt, etc and lift the whole unit intact off the tractor. You would be advised to remove this if you were going to replace the clutch anyway, so, you will be that far ahead of the game. Good luck.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Antique Tractor Wiring Basics - by Curtis von Fange. One of the most neglected parts of old tractors is the wiring. After sitting in the elements for half a century or more much equipment wiring has deteriorated to sparsely covered strands of copper or other metal. Plastic insulation has cracked, mice have eaten through the older clothed style coverings and the exposed wires have reacted to winter moisture and salts by turning blue and powdery. Terminal ends have corroded, rusted or just plain evaporated away. Aged wires not only keep an engin
... [Read Article]
Latest Ad:
Looking for a John Deere 50, 520 or 530 in good shape and preferably with power steering and three point. May be interested in a 620 or 630. Thank you.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
